Pressure
Jack_43
Member Posts: 3
Slant/Fin 150000 BTU boiler, hot water heat. (Propane) Through the wall venting.Pressure is fluctuating in one second cycles. Service man replaced the regulator at the 500 gal.tank and the secondary regulator where it enters the premises. The system is only four years old. The serviceman says the problem is in the boiler Is there anyone out there that can tell me what is causing the fluctuations in pressure. Jack
I think that
you had a reply to your thread on the same topic, below.0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
