early barometrics?
Paul Pollets
Member Posts: 3,666
A stainless model is available, and I've used several to prevent downdraft. The downdraft will shutdown the boiler if a spill switch is installed. We've had to install these caps on certain homes sitting on top of hills. Combustion = proper draft.....
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=104&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Is that what this is? Seems like it would maintain good draft, and it does still spin with the wind..
TimJust a guy running some pipes.0 -
I have
no idea. What's it attached to.? The Chimney?
Wind cap
The wind cap is designed like a venturi, to reduce backpressure and downdraft on the appliance connected.
Paul has it
Exactly, a wind venturi. The weathervane tail directs it to the strongest wind. Think of it more as a draft inducer than a barometric function.
I have seen them used most predominantly as ventilators, not as combustion inducers.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
