Boilers with Indirect Water Heaters
Greg_41
Member Posts: 16
Just installed a Buderus GB 142 with an ST 120 hot water tank, its fantastic. The boiler comes with all the computer controls and outdoor temp sensor, and will work with whatever multizone relay you like (I like Taco) and the enginereeing on the boiler and supplied manifold with bipass loop and temp controlled ifc circulator is really good and highly efficient.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=555&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
We are going to change our oil fired boiler to a natural gas one. Can someone be so kind and give us an opinion on which model might be better regarding quality, value, dependability, and warranty. We are considering the following units:
Buderus GB142.
Burnham Freedom FMC 120.
Crown Bimini BWC 120.
Peerless Pinacle PI 140.
Munchkin T140.
Triangle Tube Prestige Solo 110.
Prestige Solo 175.
PE Prestige 110 Combo.
PS Prestige 110 Boiler Only.
Any input we get would be very much welcome and appreciated.
Robert
If it
were my house I would use the Triangle Tube or Buderus
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
All fairly large boilers....
Have you run, or had a heat loss calculation done to verify that you'll need all that boiler? Oversizing can hurt with a Mod/Con just as well as with a cast iron boiler....not as much, but why waste the energy with prices where they are?
Once you get the numbers verified...I'll go with Robert's suggestions as my top picks too.JMHO. Chris0 -
Just so I know ...
Where is the Lochinvar Knight ??
We see a lot of them around here !0 -
mod con
The Burnham Freedom & the Crown Bimini are the same boiler in a differnt colored jacket. The point above about sizing is important, I know that on these 2 though the cost differenc from a 90 to a 120 is very small. the problem lies in the turn down ratio. 20% of 120 is still a lot more btus than 20% of 90, especially if you have small zones, and so sizing is important.
We used to add 40,000 btu for DHW, not so with these units.
In the end get the unit you can get good support for.
C
Re: Boiler & indirect
I think you will find that the Triangle tube Prestige 110 is the best value for a boiler. It has basically been bullet proof for us as long as installed right as with most. For the $$ it does everything we have wanted and is fairly user friendly. We like to pair it with Heat transfer superstore indirects, just our preference. Good luck, Tim0 -
We've had Great Luck
with the Buderus GB 142.
Chris is right ... start with a heat loss.
Also, The Installer is just as important as the equipement. I've seen some top if the line equipment BOTCHED.
Scott
So very thankful for your replies...
Thank you to all you generous guys who took the time to help us with our questions. This was really great of you all.
We have had a heat loss calculation by 3 different contractors and the numbers came back 92,000, 98,000, & 110,000.
We respect your opinions and appreciate you sharing your experience and knowledge.
Robert0 -
Wow, thank you for the boiler info guys...
Robert0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 27 Recall Announcements
