recirc by gravity
Mike T., Swampeast MO
Member Posts: 6,928
Yes, you should install a check valve, but you need to drill a 1/8" or so hole in the check.
The piping arrangement you describe sounds very similar to a "heat trap" used to prevent gravity circulation.
recirc
If I have a recirc line with no circulator on it, do I need to install a check valve? Also if The hot water main goes across the basement cieling then down about three feet into a manifold and then back up acrooss the cieling, is it even possible to do without a pump? Thanks.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
