Ground Water Temps
anyone know a good resource for getting normal ground water temperature ranges, nationwide?
USAF
US Air Force data available on CD-Rom from NOAA is what I use. Runs about $75 last I checked. Great resource with thousands of locations world-wide. I have posted some of the PDF's in the past, for reference.
A rule of thumb though is the average annual temperature in any given area. That is usually within a degree of normal ground and ground water temperatures below frost-line. If a moving aquifer, this will vary a lot more though regardless of data source."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Geo-thermal manufacturer's should be able to provide you with a map of the US with ground water temps.0 -
thanks to you both!0
- 86.6K THE MAIN WALL
- 54 Biomass
- 99 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
