Mod/con boiler-will it short cycle if the heat load is too small
ALH_4
ALH_4 Member Posts: 1,790
All I can say is thank goodness for natural gas or I would be freezing to death naked on a Twister mat waiting for women to knock on the door.
  • John_205
    John_205 Member Posts: 4
    mod/con boiler
    mod/con boiler with only 20 ft of baseboard will the boiler short cycle? Will a buffer tank,hydraulic separator or primary secodary piping help with the problem?
    Thanks for your help, John
  • ALH_4
    Heater
    Is it worth a mod/con in that situation? I'd go with an electric heater, like a Laing EPR 6 or a small gas water heater.
  • Brad White_185
    Brad White_185 Member Posts: 265
    I agree with Andrew
    Your 20 feet of baseboard would emit at most 12 MBH and that would be at 600 BTUH per foot, in the realm of 170F average water temperatures, well above the condensing boilers best performance range.
    More than likely the baseboard would emit 120 to 140 BTUH per foot at condensing boiler temperatures, dropping you to the 2,400 to 2,800 BTUH range.
    For that load, I would invite a dozen close friends over (at 250 to 300 BTUH each) to play Naked Twister.
    Or do what Andrew suggested. Or both. :)
  • Brad White_185
    I admire
    your use of the plural, Andrew. :)
  • Tony_23
    Tony_23 Member Posts: 1,033
    Ha :)
    And your obit would be in The Enquirer :)
    I too like your use of plural. Hey, a man can dream right ?
    My problem would be getting untwisted, and that's with just one :)
  • kpc_20
    kpc_20 Member Posts: 19
    what is the application...
    what boiler would you use? Can you jack up amt.the baseboard used? is this a temporary thing or would this be all the heat you would ever use...futue addition? indirect water heater?
