leak stop
Kent_3
Member Posts: 60
Can't find leak in customer's hot water heat system. Decided to try some kind of stop leak compound. System has wet-rotor pump and copper fin 80+ boiler.
customer might get lucky. it could work. tough to get paid for stuff like that though. yo cannot gaurantee your work.0 -
stop leak
Yes, I realize there's no guarantee, and the customer will be made aware of this. It's only a shot in the dark. Anyway, is there some kind of consensus as to the favorite stop-leak compound?0 -
Did you try
Did you try checking the heat exchanger to see if it looks steam cleaned? Water can disappear through this area and be very hard to find as it goes up the chimney.
Leak stop is a band aid.
Leo0 -
HERCULES BASE HIT
HERCULES BASE HIT actually sealed a few solder joints quite a few years ago. the luck of the draw !!0 -
not steam cleaned
I noticed the leak when I was replacing a leaking expansion tank. The boiler was cool. There is no leak from the boiler - even when it's not hot. I believe the leak(s) is somewhere in the slab-heated section. The condo is not old, so I don't think the slab is full of copper. I can't prove this, though - I've searched everywhere and can't find a manifold or anything.0 -
Thank you much. I'll try it.
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 948 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
