Does anyone from Riello hang out on the Wall?
The Boiler Dr.
The Boiler Dr. Member Posts: 163
I believe both the Model 40 and 50 are now available in 120 volts. I recently purchased a Model 50 for use with 120 volts.
  • Steve Garson_5
    Steve Garson_5 Member Posts: 11
    In looking at the European Riello web site, they have a gas burner that seems like a dream for steam boilers.
    The Model 40GS/M is a modulating proportional burner with 22Kw to 104Kw (75,000BTU to 355,000BTU). For a steam boiler, this would be great to have available, with the ability to run 140,000BTU to get to steam and then drop to 75,000BTU. But it only runs on 220VAC, 50HZ.
    Is there any chance that Riello might come out with a 120VAC 60HZ version for North America?
    Steve
  • Steve
    Riello is a great product but the boiler itself will need approval to run that way.
    To answer your question, if the demand is there Riello will make-it compatible.
    Dave
