'83 burnham p-206-w series 2
[Deleted User]
what's the lowest temp at which i can operate this old gal without creating a condensing problem? i'm running a tjernlund power vent
probably around 150 outlet temp on boiler depending on the delta
t of system. Usually you want to not go below about 135 - 140 degree return temp.0 -
hmmm, when i installed
this system, i had approx 0 knowledge/planning, and not too much more real understanding now, so, bear with me on these questions
i'm controlling it with a h-well L8148e, set at 180degs. with two circuits of staple-up and taco mixing valves, i can't keep the circuits lower than 130 and 140degs supply respectively. now, right after firing with the pumps running, and measured with a cooper contact thermometer, primary loop, my boiler supply is at 218degs and the return is 214. circuits as mentioned
so here's what i think; i have more boiler than i need, and/or my pumps are too big/too little heat loss to the floors
so, without making changes, new pumps/another zone/water heater, to the system, can i just lower the h-well to 160degs? would the boiler care, as long as the supply/ return aren't out of the 15-20deg drop?
Way too high, lower it to 155 to 160, should be much better.
thanks for the helpful
and prompt responses. will do. and i'll keep you posted
oops! the h-well doesn't have a setting below 180. looks like a new one is in order0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
