Propane verses oil heat
able
Member Posts: 16
Condensing oil mestek ray or peerless pinacle I havent installed any but any thing that condenses is direct vented not into a chimeney ?
Hi all.
I need to replace my old oil boiler. I am contemplating going with propane. I use it with my oven now. I will be using Co. tanks so the only cost will be to run some piping in cellar & some outside, I was told by the propane co. I could do the work. However the boiler will be about $600.00 more than the oil boiler, they are both low mass & condensing. My question is should I stay oil or go propane? Also if I stay oil I will have to put in a chimney liner an additional $2000.00 more. Any help would be great. Thank you Mike0 -
What
condensing oil boiler?
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
