Triangle Tube Mini Smart
Derrick Ellefson
Member Posts: 64
Has anyone tried using the triangle tube mini smart on ant thing other than a prestige? Maybe with a cast boiler?
It wouldn't do it on a high mass boiler unless it's a hot boiler.
The Mini-Smart is dependent on the boiler being able to heat up within a very short period of time.0 -
Like keeping the boiler at a constant temp? Have you had problems getting all the air out on the boiler side on start up?0 -
Ya like a constant temp. Kind of an energy waster though...
A typical cast iron sectional will take 2-5 minutes to come up to temp. A Prestige Solo 110 takes less than a minute to get to full fire. If it takes any longer it's too late.
Also you will need to control it. You will need an aquastat that has a bulb that will fit the Mini-Smart.0
