PEERLESS PI-T80
[Deleted User]
I WILL BE INSTALLING SOME PEERLESS PIT80- LP WALL MOUNTED BOILERS FOR A HABITAT FOR HUMANITY PROJECT in NORTH JERSEY WITH A LOW BOY 30 GALLON INDIRECT UNDERNEATH IN A CLOSET WITH BOTH ON THE SECOND FLOOR. 2 ZONE HEAT. HOW WOULD YOU RECOMEND DOWN PIPING THE ZONES? PRIMARY-SECONDARY OR STANDARD PIPING? THE FLOW THRU THE BOILER ONLY REQUIRES A 007 FOR FLOW THRU THE BOILER. STILL NEED PRIMARY/SECONDARY? ZONES ARE 3/4" PEX W/ 3/4" SLANT FIN.
- 120 Geothermal
