Help! Mystery Valve
Steve Ebels_3
Member Posts: 1,291
A relief valve from a hydraulic system such as you would find on a backhoe or dozer. Wouldn't be surprised if that's where the original came from.
Where do I find this
I am a distributer. A customer of mine is building a test rig, to hold vessels at 900psi. He has a pump that discharges at 1100psi into a 3 port bypass valve...the valve holds the 900psi and any excess is discharged out of the third port. He already has an older fuctioning rig with that valve on it (no tag of course). A picture of it is attached. Can anyone tell me a manufacturer that can provide something like this?0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
