electric hot water heater used for hydronic baseboard
Jeff Lawrence_25
Jeff Lawrence_25 Member Posts: 746
of the water, it's the heat that's in the water.
It's the amount of heat that's put into the water that heats your place. Size/capacity of the heating unit doesn't matter, it's the BTU input that does.
A heat loss should be the first step.
  • frank maltese
    frank maltese Member Posts: 1
    hello,
    can you provide me with information regarding
    the use of a 40 gallon electric
    hot water heater to run my three zone baseboard
    heating system.
    I have a total of 400 feet of 3/4" piping and
    calulated the volume of water used to be just under
    10 gallons.
    Is this feasable, effecient, and what parts would I need to make this work.
    thanks
    frank maltese
    frankmaltese@netzero.com
  • Steamhead (in transit)
    Steamhead (in transit) Member Posts: 6,688
    I wouldn't do that
    returning water will quickly mix down the hot water in the tank, and unless the tank has those Godzilla heating elements in it, it will take it a long time to recover.
    Also, unless you're in an area with really low electric rates, you can probably get a better cost-per-BTU from gas or even oil.
    Have you done a heat-loss on your house?
