No hub coupling for boiler flue pipes (ME)
ME
Look at Fernco proflex or strong back series
http://www.fernco.com/proflex.asp
All are approved for venting lol, just not what you are thinking
Remember the thin rubber couplings on 90% furnaces? they worked
Best regards-
  • Does anyone know of a manufacturer...
    that approves their coupling for use in a flue pipe application. We have to make a transition from PVC to Stainless Steel and I'm thinking that a no hub coupling is exactly what the doctor ordered.
    Mission says NO, chemically compatible, but nothing in 3" X 3.5"
    TIA
    ME
  • Dave Stroman
    Dave Stroman Member Posts: 766
    I wonder if any manufacturer will "approve" their couplings for this application. Would the PCV manufacturers approve their pipe for vent pipes? In a vertical pipe, a fernco might work, but probably not in a horizontal pipe. A shielded coupling would be better. I think the most important thing is to find one that fits properly. They make couplings that go from PVC x TWP (thin wall plastic), and PVC x copper. Have you tried these? A SS fitting, like a coupling or a 90, might fit better than the plain end of a pipe.
    Dave Stroman
  • Bryan_16
    Bryan_16 Member Posts: 262
    vents
    Windows with chimneys? Bryan
  • Darren_14
    Darren_14 Member Posts: 7
    z-vent
    Have you looked at novaflex.com go to the Z-flex section then click on the appliance adapters. They have a universal appliance adapter that may be what you are looking for.
  • Rich Kontny_3
    Rich Kontny_3 Member Posts: 561
    Mark
    Clampall makes a transition bushing from pipe size approx. 3.5 to 3.125. It is used when plumbers transition fron IPS to copper DWV. I don't see any compatability issues only temperature issues.
    Rich
    hot_rod Member Posts: 27,674
    I e-mailed Mission Rubber
    about max temperature for their end caps for use on solar tubing installations. 212F is the limit for their neoprene based product.
    hr
  • JohnNY
    JohnNY Member Posts: 3,375
    Just spitballin' here, but...
    ...can you increase the 3.5" to 4" for a short section? You'd have more 4" x 3" options.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • Don \"Grumpy\" Walsh
    Don \"Grumpy\" Walsh Member Posts: 184
    A Possible source
    Weil-McLain uses a rubber and stainless banded type connector on the Ultra Boiler. Perhaps they could suggest an answer.
