Is it possible to replace oil burner with gas burner
Eric Masson
With the rising costs of oil, I'm wondering if it's possible to replace my Beckett model AFG burner with a gas burner. Can this be done, and beyond replacing the burner, are there any other gotchas?
It's possible
but whether or not it's a good idea is another story. What type of boiler do you have? How fast is your local gas monopoly raising their prices?
"Steamhead"
At this point I'm not sure whether or not it would be cost effective, I do understand that oil is more efficient than gas in terms of BTUs. I have a Vaillant boiler, not sure what model. I'm just trying to determine if it can be done.0 -
Yes, it can be done. Expect about a 2% reduction in thermal efficiency by going to gas in lieu of oil. Could be higher... depends on the boiler.0 -
The Vaillant is a tough boiler to fire I would be cautious about trying it on this one0 -
Sometimes it's not safe
And, it's never cheap, the unsafe part is some boilers don't natural draft so the mfg. doesn't allow gas conversions. I would make sure the mfg. approved the switch, some do some don't. To convert in Wisc. you need electronic ign. and an elect. vent damper added, this plus labor plus the burner, vent pipe, chimney clean... puts you well over $1000. To save $ first have your oil unit cleaned and set up by a pro. then check your usuage and make a payback calc.0 -
You would need
a burner that can fire a positive-pressure boiler. The only one I know of is the HeatWise SU-2A.
It might make more sense to tighten the house up first- insulation, new windows etc- if you haven't already.
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
