aphalt heat gain
jp_2
Member Posts: 1,935
as far the the use of "gain" there isn't any.
but the black surface should be about the same as the solar power delivery in you region, watts/sq meter.
asphalt heat gain
anyone have any calculations as to how many btu's can be gained per square foot of asphalt driveway with 3/4" pex 9" on center. curious to know if anyone has done this or is there anywhere to find a chart to show btu's per square with full sun at what outdoor temp, wind speed etc. Any info at all would be helpful0 -
we've seen it, it's very significant in some cases. no calcs but I imagine solar design manuals would be a good place to start.0 -
Do a search.....
for "Solar Driveway" on this site.
I believe Mad Dog has done this.
JimThere was an error rendering this rich post.
what do you mean there isn't any?
we were pulling 115 on a cloudy day from a driveway in MA.0 -
misunderstand
gain should imply amplification.
if the sun delivers 100watts/sq meter in your area, the asphalt will produce less than 100 watts, if it picked up 110watt/sq meter then you would have gain.
maybe what the poster is really asking for is emissivity?0 -
Lehigh UNiverstiy
did a study at Mario Andrete's house and figured everything at 127 BTU/sq ft. Angle was slightly off from Logitude for max gain.0
