Peerless -40 indirect water heater clogged up?
chris_93
Member Posts: 84
Might want to check to make sure the proper circ. pump was used. Also most manf. require min 1" lines to the coil. just a thought.
I recently added a peerless indirect water heater to my boiler. Soon after it was taking some 60 minutes to recover. The installer said it was from sediment in the water. We have city water and never had any other problems. Are there any problems known with these heaters, or with bad water?
Thanks.0 -
Maybe there is a coil cleaning procedure? Have you looked in the manual, the Peerless web site and then their tech. support?0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 972 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
