flow control location
Al Letellier_21
Member Posts: 402
Terminology is not always the same everywhere, but if by flow control you mean flow checks, the answer is yes you can. If the boiler and all the controls are above the slab and the piping drops, gravity flow will be minimal. Why not use circulators with internal checks.....talk about simplifying the piping!!!
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=522&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
I have a two zone, two circulator, snow melt system with a primary boiler loop and variable speed injection pump.
The pipng for the snow melt zones come up out of the ground. Question ? Can I install the flow controls on the return pipes rather than after the circulators . I am trying to simplfy the piping.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
