DHW Recirc line
tim smith
Member Posts: 2,886
then just do some branches off that point to other main used fixtures. One home run recirc with branch recircs would be pretty easy. Just a thought.
DHW Recirc line
Does anybody have any experience or suggestions on how to install a domestic hot water recirculating line for a homerun/manifold system. This is new construction so everything is still wide open. Thanks in advance.
Wild Rover0 -
Essentially...
... you don't want to attempt recirc on a manifold system. If the runs are going to be quite long, perhaps switching to a "structured plumbing" approach would make better sense. Manifold should deliver hot water quickly with little waste. If it doesn't, there is too much volume in the system between the heater and tap. Smaller diameter lines and/or better manifold placement could help. Good pressure is needed. Search "Gary Klein structured plumbing" to see some interesting articles on how to get hot water wasting only one or two cups.
Yours, Larry0 -
what is the ...
layout? If you have the home run set up a recirc line is less needed...usually. Where is the water heater? What is the longest run? What size tubing ar the branches? kpc0 -
Longest run
Thanks for the replies. The longest run is just about 100'. And all homeruns are probally going to be 1/2". I'm looking to cover all of my bases.0 -
ya' know
in situations like that I would do two manafolds. ...then do a recirc line in the basement between the two manafolds and the water heater....kpc0
- 114 Geothermal
