superstore
Dave_49
Dave_49 Member Posts: 19
I was given a small superstore indirect water heater. It is quite old. It looks to be in good shape. Short of hook in the little guy up. How do I know if it still works? Can I simply pressure test both the storage tank and heat exchanger? If they hold pressure would it be safe to assume the heat exchanger will still work? I was given no information about the tank.
  • Rich Kontny_3
    Rich Kontny_3 Member Posts: 561
    Big D
    I would contact the manufacturer and ask what they would suggest. There is a procedure for filling the tank before the coil on most indirects (or vice versa) so you may want to contact them before you put any kind of pressure in the indirect.
    Rich K
  • Dave Stroman
    Dave Stroman Member Posts: 765
    No big deal. Just hook it up to a hose and pressurize the tank with water. If no leaks, you are good to go. No need to test the HX separately. A leak in that will show up when you test the tank.
    Dave Stroman
    hot_rod Member Posts: 26,969
    Check the condition
    of the coil if you can. I believe that is a finned copper coil and they sometimes need to be de-limed. A flashlite or one of those Rigid see snake cameras works.
    hr
  • tim smith
    tim smith Member Posts: 2,898
    One other item, very important
    I would want to know that it was used for heating potable water. Someone could have been using it for a non intended use. Just a thought. Tim
  • bruce_21
    bruce_21 Member Posts: 246
    If its been sitting a while, I'd want to disinfect it with bleach overnight just to be sure there are no bugs in there.
