Heaters in Summer
Nadine
Member Posts: 1
I work in a small office, which has it's own gas boiler / heating systems.
Lately, the heaters has been coming on, even though the control box is switch off, not on constant or timed.
Will the radiators still come on if the actual rads are still turned up higher than 1.
Is it a thermostat or boiler or electrical problem?????
Many thanks,
Many thanks,
heaters in summer
Just noticed you didn't get an answer. Sorry about that.
The standard answer here depends. Does the boiler make hot water as well? You could have a flow check issue. Best to have a pro check it out. Use the find a pro feature on this site to locate a good one
- 120 Geothermal
- 394 Solar
