Oil flue sizing
Chris_12
Member Posts: 9
Looking for a chart to close a dispute on whether a flue serving a oil furnace and oil water heater is undersized.
Currently the furnace (140k) fires into an elbow through a tee with draft damper into a 90 through a tee servicing the water heater into the flue. The water heater fires into a 90 on top then a 45 and short pipe a 45 and into the tap of the tee. The tee branch is horizontal as is the pipe servicing the water heater (will be addressed). I know this should be a wye.
The issue is sizing at this point, the physical layout will be addressed separately.
Looking for a NFPA chart or similar. Anybody?
Field control..................
http://www.fieldcontrols.com/draftcontrol.php
About half way down you will find Multiple Appliance Location Recommendations0 -
That is great for the layout and draft damper, but I still need a chart on say BTU/square inch of flue size.0
- 62 Biomass
