high side of drop header
Chips
Member Posts: 33
Can I run my two 4in. risers off the high side of the 3 in. drop header, similar to what Ron Jr. did on his beautiful counter flow system? I know it is not the recommended boiler piping for a 1 pipe gravity flow system with a dry return, but it would save me from relocating my existing risers and mains. The A dimension is over 10 feet and the mains are a couple feet above that.
Chips
Chips
if you have two
4'' risers, then why do you only have a 3'' header? am i missing something here.
sketch
i think you gotta clarify the piping arrangement with a sketch. a pitcher is worth a thousand words thing.0 -
I will be installing 2 new megasteamers piped as shown on page 67 of Dans book and similar to page 14 of Burnhams heathelper. The common drop header will be run between the 2 boilers so piping will be very tight. I plan on using 4 if I can fit it in the space.
Chips
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
