Electrolysis in steel pipe?
greg_47
greg_47 Member Posts: 9
can you describe what the inside of the nipple looks like?
What is the PH of the system? is entrained air a issue with the system? ie no microbuble resorber of non barrier tubing. Is the steel nipples in the system less than 5% of the copper?
  • ArcticManiac
    ArcticManiac Member Posts: 2
    I have a customer who has an issue with his piping system. Apparently every four years the nipples rot out or a perfarated (pin hole leaks). I suggested he may have Electrolysis. My question to you would be how would you diagnose it and what could cause this to happen to his pipes?
  • Rich Kontny_3
    Rich Kontny_3 Member Posts: 561
    Artic Man....
    Water quality and fluid velocity would be my first guesses.Many a nipple has been Swiss Cheesed by the wrong pump application.
    How is the weather??
    Rich K.
    hot_rod Member Posts: 26,825
    color of the fluid?
    generally if you have a lot of O2 ingress you will see a rust colored water. Typical of the old non barrier radiant tube jobs.
    ph would be easy to test but iron pipe should be able to handle a fairly wide range.
    Even similar metals, under the correct conditions can corrode due to electrolsis, look for current running through the pipes.
    Over sized pumps, un-reamed pipes can cause erosion corrosion also.
    Find a water treatment pro and send them a fluid sample first. Do some calcs on the required pump size.
    hr
  • ArcticManiac
    Some answers
    Well thanks for the replys. I will check with him on the pump sizing. Also the PH of the water and color. Thanks for the advice and i will be back with the Info.
    The weather in Alaska still sucks right now. Its supposed to be spring but we keep getting snow!
