Aquastat or vent damper problem
Steamhead (in transit)
Member Posts: 6,688
either the control is bad, or improperly set, or there's a bad connection somewhere, or......
Click on Resources above, then Find a Professional and follow the directions.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Hi I have a problem with my heating can someone help. I have a utica gas boiler with a honeywell aquastat and a effikal vent damper. The problem is when I call for heat my aquastat clicks on and heats up the cuirculator. I have the vent damper in the automatic operation position With never closes stays open. I have to press down on one of the relays on the aquastat then it turn the burners on. It would stay on until it reaches the 180 degree mark. Then my air handle turns on. So it could work for 5 min or one day but when it stops working I would have to repeat the process. I need help in order to figure out with part to replace. Sorry If I didn't make sense to some but I am a novice at the hvac game. Thanks
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
