solar system install
Bob Gagnon plumbing and heating
Member Posts: 1,373
But I agree with the broke hippie. If the panels are still working and you maintained the PH in the anti freeze all those years, I would put them back on the roof. What am I supposed to do, throw out my evacuated tubes after 30 years if they are still working?? Why did you hold on to 30 year old collectors anyway if you are not going to use them? Worrying abot the roof leaking under the collectors is just another excuse for not installing solar. Finding excuses is easy, what's hard is finding the money and time to install a system and try to make a difference.
Thanks, Bob Gagnon
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=331&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Thanks, Bob Gagnon
Here is some pic's of solar system we just finished .
We have 2 system's 1 is for domestic hot water (drain back system).The other is for electric .0 -
Where is the snow? I'm guessing your in the "south".0 -
Good job Jim
Could you tell us the details of the job?
Thanks for going solar, Bob Gagnon
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Pics
Could you show us some pictures of the mechanical side of the solar thermal installation?
Darin
solar install
I will post more pic's shortly i have to finish all work in mech. room first .
I just love the way there is no water or glycol in panels on roof for domestic production .
The storage tank is a little large but able to install up in loft above the space .0 -
Look at them leaves
Where are you located? I'm movin tomorrow! My system last month after a heavy snow.0 -
what happens if
What happens if the roof gets a leak ? is it difficult for a roofer to do a repair under those solar pannels ?0 -
When your roof leaks
what in thirty years?? Think of what the gas and electric bills will be in thirty years, you will be happy to take them down, replace the roof and put them back up again.
Thanks, Bob Gagnon
I don't think that someone will reinstall 30 year old panels Thanks Heatmeister...0 -
Uh
I take it you have never met a broke hippie before0 -
I Got
I Got some 30 year old Collectors that I'll sell to you Bob >>>>How about it <<<??? A buck a pc ???0 -
when I saw the topic name, I wondered if it took you 6 days and you rested on the seventh?
TimJust a guy running some pipes.0 -
No was drinking sie die Bier...0 -
For the Glass... :.)0 -
Don't move Ron
A tilting collector mount would keep the snow off in the winter with a steep tilt, and collect more energy because it is pointed right at the low winter sun. Tilt it at about 45 degrees for the spring and fall, and nearly horizontal in the summer, if you use that much hot water, if you don't, simply tilt the collector away from direct sun, to find your sweet spot. A simple improvement like that would make solar much more efficient. We should do a solar job together this year, I'd like to pick your brain.
Thanks, Bob Gagnon
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 972 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
