shoring
bovide,
You need to know the OSHA standard for excavation (or someone does) to be a competent person. You can use a trench box or angle the sides back depending on what type of soil you have. Let's talk more about this. Bad trenches kill plumbers every year.
Larry
  • bovide_4
    bovide_4 Member Posts: 161
    how do I
    build a timber shoring box. The job is to install an underground oil water separator. I plan to use 3" x 10" x 10" planks with cross braces. I went to the OSHA website, but pictures would be a lot more helpful. The hole is 9' deep x 12' long x 9' wide. The soil is stable.
  • Jim Bennett
    Jim Bennett Member Posts: 607
    Trench box
    Many rental yards have trench boxes available. They can bring it to your site and you drop it in with a backhoe.
    Saves a lot of man hours building.
    Here's a link to United Rental.
    Good luck, Trench safe,
    Jim
    http://www.ur.com/index.php/equipment/rental/browse/?category=Trench+Safety
  • bovide_4
    going with
    the trench box from American Shoring. Thanks.
  • Larry (from OSHA)
    Larry (from OSHA) Member Posts: 745
    Bovide,
    Thanks for thinking about how to do the job safely.
    Larry
