first time with rhomar
Tim_41
Tim_41 Member Posts: 153
I was skeptical at first but we
injected some rhomar 9100 into a radient system the other day. It also has 3 panel rads. Just flushed out today. Wow! The murky water that came out was impressive. We than put the inhibitor in the system. The system is a 11-44 vitodens with climate panels. I just wanted to thank everyone for the advice from the wall.
I would reccommend the product to anyone.
    hot_rod Member Posts: 26,872
    about your chemical romance
    what was the reason for using the Rhomar? Was the system showing some sort of symptoms? Low heat transfer, noise?
    It's a great product, Rhomar cleaners and inhibitors and they work as well or better than advertised.
    hr
  • Tim_41
    HR,
    HR, its a new system with no problems. With all of the discussion about water quality with the mod/cons and even CI boilers, I don't want to cut any corners with system performance and water quality. I wish I had known about the subject a long time ago.
    You are wise
    to use a cleaner like that. I feel the life expectancy of thin walled HXers will be directly related to fluid care. That includes the important initial clean and flush.
    hr
