Myson wall heaters
Gary Maxfield
Member Posts: 1
I want to install 5 Myson hydronic wall heaters, can I install them in series and what size tubing is required? Using a taco 1/25 hp circulator.
If they have bypass valves
you can install them in series, but best way, IMHO, is a "home-run" system. One 5-drop manifold (5 supplies, and 5 returns) with a piece of pex going from each panel back to a dedicated tap on the manifold. Each panel gets the same water temp and there is less pressure drop this way.
Have done it this way multiple times and it works beautifully.0
- 87.4K THE MAIN WALL
