steam to hot water converter
Tony Conner_2
Member Posts: 443
...water treatment company to work with you, and test the condensate. Unless the closed-loop is filled with soft water, a hardness test on it may answer your question.
I have quite a few of these on my job. I would like to know how to leak test them? Steam enters the shell at about 8 #'s and water is pumped through the tube bundle inside of the shell. I would like to perform some kind of test without disassembly. Thanks0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
