zone valve manifold
Big Will
Big Will Member Posts: 395
I think they are made by Zurn for my small manifolds with 1/2" pex. They are really time savers. I can't find a 11/4 or 11/2 manifold with 3/4 or 1 inch branches for my zone valves.
    hot_rod Member Posts: 26,951
    I get 'em from
    Watts Radiant. Alberta T-Drill and Sioux Chief also offer copper manifolds.
    hr
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    ME TOO!
    I understand what you are looking for I am also using the Caleffi manifolds as a"Main"Boilerroom Manifold, it works great for Smaller Systems(Up to 100000 something Btus)...
    I am also looking for 1.25 inc and 1.5" versions of these one pc brass Manifolds with the Flowsetters and purgepoints,Shutoffs, were's I could just screw the Zone heads directly to it.
    Not CU with Zonevalves soldered on to it !
    Anybody got this? Richard from Heatmeister..
    Caleffi has
    a new high flow manifold, 1-1/4" manifolds in brass. The 663 allows up to 3 gpm per branch depending on the configuration.
    hr
    www.caleffi.us/en_US/caleffi/Details/News/files/01044-06.pdf
  • Big Will
    Found them
    Zurn part # QHCM64 11/4 by 3/4
    QHCM74 11/2" 3/4
    QHCM84 2" 3/4
