How to calculate EDR of this style radiator?
Steve Garson_2
Member Posts: 712
I have many of Dan's books but need help in determining the EDR of the radiator on the attached photo. I am guessing that it should be considered a one-tube with 1.66 feet per section, but I am really clueless on this one. For one-pipe steam, circa 1915 building.
The radiators are 23-inches high and come in 30 section and 60-section versions.
Steve from Denver, CO
Peerless Wall Radiator
Steve,
That looks like a Peerless wall radiator. It's in Dan's EDR book (Every Darn Radiator). It should also be listed in "The Ideal Fitter" I think that there is copy of it in the "Library", here on the website. Good luck.
Ross0 -
I am challenged to determine the correct EDR. Attached are the pages from the Peerless catalog. Our radiators appear to be the Model 7-B.
I have 30-tubes, so it appears to be three 7-B sections. Is the radiation 7 square feet per section x 3 = 21 square feet?
Am I reading this correctly?Steve from Denver, CO0 -
Looks correct
Steve, that looks right. i.e. 21 sq. ft x 240= 5,040 btuh.total.0 -
Steve, on that type of radiator
each unit of two large tubes at each end and four smaller tubes in between makes one section. The sections are screwed together with right/left hand threaded nipples so it's hard to see the joints.
Thanks!Steve from Denver, CO0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
