natco firecore
bob young
Member Posts: 2,177
Thanks Dan, buit you cannot deal directly with the manufacturer . must go thru a distributer . 2 " pump lists for well over a g
firecore system
anyone know a local bklyn or vicinity distributor for a pump for a natco firecore boiler w/ storage tank. 2 " stainless pump. laundramat job.0 -
National Combustion Company, Inc.
104-11 180th Street
Jamaica, NY 11433
Phone: (888) OK NATCO | (888) 656-2826 | (718) 291-8400
Fax: (718) 291-68700 -
pump
Try Ipso of NY /Laundercenter in the bronx- 718-991-0600. you should be able to get 15-20% off Good luck0 -
one more thought
When I was in the laundromat business, we had a fire coil boiler in one of the locations and I remember the complete pump assembly was pricey. Natco is not a true "manufacturer". It was a relabeled Teledyne-Laars as I recall0 -
done deal
thanks much, Dan. i actually found a dist. in jamaica & got 30 % off. pump must be made of gold. it is installed & done with.0 -
million $$$ pump
you could be correct on that ,Dan. pump is made by goulds. picked it up at natco. looks like a real shady operation. extremely secretive. not my cup of tea. these laundramat guys usually do all their own work. they can have it. real cheapskates0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
