Change Wirsbo t-stat to read F
Gene Davis_3
Member Posts: 51
My plumber is skiing in Canada, and my Wirsbo t'stat (heating only, A3030101, two wire) is showing temp in Centigrade and not F.
This, after a power outage. The prob is with just one t'stat. There are six others in the house.
The little one page "owners manual" doesn't say anything about changing display mode, and I cannot find any literature at the Uponor Wirsbo site.
I thought that one of you wizards of Wirsbo might know.
C
If I recall correctly, there is a button on the back that allows you to change from C to F. The button allows access to this setting and then the up-down button on the front is used to toggle fom C to F. Hope this helps. -DF
Take cover off
without disconnecting wires, and you'll see a black button. If you press that you'll see the display setting change. If you keep pressing the button you'll also have access to min. and max settings, caution you can also turn the stat off setting also.
you also can try taking the cover off. inside you will find a dip switch change it from user to installer you will get alot more options0 -
UHOT Thermostat Instructions
See attached file for the instructions.
Page 4 describes the button inside the thermostat for extra settings0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
