help explain this?
Timco
Member Posts: 3,040
Thanks...I have rode a bike before, but nver tried to explain it...
Tim
Tim
Got into a swamp cooler (evaporative cooler) conversation today. Cust says no volume of air like it should have. Claims it needs a larger motor. I say I have fixed this before, and it is not the motor's problem. All motors are the same RPM I explain, and it is a problem with ratios of drive / fan pully. He in not so many words says he does not think that is it, but I have put a larger pully on the drive and smaller on the fan with great results...TONS of air. Besides saying it is like a 10-speed bike, how does one explain this?
TimJust a guy running some pipes.0 -
motor
Its all in the ratio. If you have a 10" pully on the drive side (motor) and a 1" pully on the driven side (fan) every time the drive pully makes one revolution the driven pully will make 10.0
- 87.4K THE MAIN WALL
