Laars Endurance Return Thermistor Fault
BILL_103
Member Posts: 1
ANY RESPONSES
LAARS Endurance return Thermistor Fault
Hi, I have a Laars Endurance Heat/Hot water system and I have an F-6 fault. I looked in the manual and it says it's the return thermistor. Located the thermistor. Question is, does the system have to be shut off and drained to replace? Looks simple enough, just unscrew nut on pipe and replace, but will water pour out while replacing? Also, where can I order one of these? I'm located in Plymouth,Ma. Thanks!0
- 87.4K THE MAIN WALL
