Gorton #1 and #2
RonWHC
Member Posts: 232
is also available w/ 3/8" connections. Your point?
Can anyone explain why the Gorton #1 has a 3/4-inch thread and the Gorton #2, which vents like four #1's has a 1/2-inch thread?
Is a 1/2-inch tap OK for two Gorton #1 on a manifold. It just is not intuitive.
Just wondering.
SteveSteve from Denver, CO0 -
My point is simply that it seems that the smaller venting capacity would have the smaller thread.
If you use multiple vents, what size nipple is really needed?Steve from Denver, CO0 -
Gorton #1 Has
both 3/4" AND 1/2" on the same vent. The 3/4" is MPT and the 1/2" is FPT. Very convenient I think.
The core diameter is still that of a 1/2" pipe which exceeds the venting capacities you are dealing with.
Personally though, if you are making a Menorah or combining vents on a common expanded line, I would use at least a 1" pipe to keep the pressure drops low.0 -
Thanks all!
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
