Triangle Tube Prestige Excellence
adambuild
Member Posts: 420
Mod/Con 30-110mbh with self-contained 14-gallon indirect capable of 180gph! Anyone know if this is available yet? If not, when? If yes, how are they?
Thanks, Adam
Thanks, Adam
Great outfit Adam,
been out for awhile now,,, just make sure of your DHW, and CH heating needs, and you`ll be fine.
TT is a good product.0 -
I was just told that the self contained unit wasn't coming out until May. I am certainly looking forward to it.
Boilerpro
180 gph is only 3 gpm remember. a typical shower is 2.5 GPM.
however, if that's all you need, yes, they are out now. I believe just released in the last few weeks.0 -
who in NH...
Stocks Triagle Tube products??? Not granite Group. Not Redlon & Johnson, Did not see anything at FW. Webb....0 -
TT PRESTIGE EXCELLENCE
They are now available from triangle tube. yes they claim it puts out 180GPH DHW. this boiler will work great for space heating and should be good on a 1.5 bath house. I offer customers a 1.6gpm alsons shower head that makes it feel like a 2.5 gpm shower head. please remember a shower faucet mixes hot and cold water together and comes up with 2.5gpm or the 1.6gpm flow. you could install a fiberglass holding tank to raise the temp of cold water before it goes into the indirect on this prestige excellence boiler or use the TT regular prestige condensing gas boiler and TT phase III smart stainless steel indirect water heaters 20 gallons to 119 gallon models depending on your domestic hot water needs. great products.0 -
coastal winair in southern maine does; perhaps other win-nelson companies do as well..0 -
the shower faucet only mixes hot and cold if you have the hot out on your heater set too high for comfort. that raises the dT you need on your incoming water which in turn reduces your allowable flow rate through the unit; there is no cheating the physics of on-demand hot water production, a BTU is a BTU and it has to get into the water at the rate you are using it. either 3 GPM of usable heat is useful for you or it's not... all depends on usage.
those shower heads sound good though, clients are happy with them?0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
