Steam Boilers
ddlong1286@yahoo.com
Member Posts: 139
Hi all,
The company I work for is looking at replacing 2 Pacific Steel Boilers, M# 415-BG, 2100MBH, 47 HP. The control panel is M# NP240-G-E, 3500MBH.
My question is what would be a good replacement boiler? Do they make copper fin tube steamers?
The system has a vacuum pump, ITT M# 10VLR2-20-35.
Don
Don
Bryan Steam
is one brand, flexible steel tube types, not copper. Miura is another, more of a steam generator. I am not familiar with Pacific and what footprint they take up so am erring on the side of smaller boilers.
Firetube boilers such as Cleaver-Brooks can do well in the lower horsepowers but water tube boilers can tolerate higher pressures. I am not sure what pressure or process you are running.0 -
Application
Hi Brad,
Heating with radiators and one steam coil in ductwork. Low pressure, but not sure how low.
The boss mentioned copper fin tube, but had not heard of a manufacturer for this type boiler for steam.
Forgot Crane Co. was on tag with the Pacific name. Approx. 5 ft wide and 8 ft long.
Don0 -
Hi Don
I would go with Bryan at least as a place to start. They have a few models. I do imagine it is low pressure, not process like a laundry for example.
Get modulating fire if at all possible.
The steam coil unless it is cast iron (and assuming that the radiators are also cast iron) would dictate a fairly constant pressure operation and with traps. Not a "cycle" approach as you might on an average house.
If the coil is low-mass and is obviously heating air (also low mass hence volatile to changes), you can see how that zone may suffer unless the steam pressure is always available.0
- 87.4K THE MAIN WALL
