w-m bcp-3
![[Deleted User]](https://secure.gravatar.com/avatar/df1311a8c978bcd452812a433c886c5f/?default=https%3A%2F%2Fvanillicon.com%2F250ce9fbde904513227616dd24c51051_200.png&rating=g&size=200)
[Deleted User]
good, bad, indifferent?
I've used it to stage two packaged CGa model boilers. It is a simple little control that just closes a dry set of contacts when 1-boiler can't handle the load. For a on-off multi-boiler control its just fine.
I definitely wouldn't use it for a mod-con. (If you have to use it for a mod/con, program the time between stages to maximum, to allow the mod/con to do its thing.)
It's OK, for what it is...0 -
thanks
and 2 mods was how we did it and we wondered if it was worth it. but i don't remember how we timed the stages and that may be the answer0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
