Foaming steam boiler
kpc_14
Member Posts: 38
We installed a gas steam boiler last fall, standard residential, nothing fancy, cleaned and skimmed as normal, all okay, EXCEPT it keeps foaming! At first every week, then every two weeks, now about every 6 weeks it will get dirty and surge and go off on low water. We go out and skim, and everything will be fine for weeks. Then it starts foaming again.
Any idea how we can clean system once and for all, and what might be continually coming back and causing the boiler to foam??
Mark0 -
ph
Check your ph Mark. If needed (and I'm guessing it does) bring it down to between 7-9 and you should be ok. Vinegar will do it, But then your whole house may smell like dill pickels! Pool chemicals will work too.
Good luck, Rich L0 -
I had the same problem with mine and after skimming it for the millionth time I broke down and bought some Hercules boiler cleaner. I followed the instructions, then skimmed the boiler again and it finally seems to be clean for good now.0 -
As said,
check the ph,,, if within 7-9 then it`s dirt,, sometimes it takes a lot of skimming and blowdowns to finally rid the system of it, depending-on how bad it was.
I had a system that took about 8 months to finally clean-up,, now its fine.0 -
try
draining the wet returns, allow the steam to go into them, keep their drain valves open wasting the condensate..this steam cleans the wet returns, then hose flush the wet returns.
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
