controlling water temp for in floor heat loop
hot_rod
Member Posts: 24,472
product works on pex at high temperatures. No need to install any mix system. Easier to install if you have a lot of subfloor nails protruding, also.
hot rod
hot rod
small in floor loop attached to conventional hot water system
Have a customer that has a conventional hot water system and boiler-gas fired- on coldest demand water temp averages about 160F with cast iron radiators. We are adding heat to kitchen under floor in joist pockets with finished tile above. What are the choices to control the water temp on this loop, so it does not get to hot, but can work in tandem with existing system with 1 thermostat, running the whole house?0 -
simplest method
taco I series mixing valve.
OR:
install whole house outdoor reset and use a ball valve to balance(use as mixing valve) the water temp in that area that will alway be proportional to the rad water temps0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
