HW boiler piped into furnace?!?
lee_7
Member Posts: 458
Correct. On a call for heat, the boiler fires sending hot water thru a coil on top of air handler. Actually works quite nice. I have done it numerous times as supplemental heat for a heat pump instead of electric resistance coils.
I've never seen this before but a friend has a hot water boiler (IN-6) that was hooked to CI rads. A furance was installed and taco 007's added to the return and supply while the supply and return are piped right into the top of the new furnace with two zones. It's also got an ac condenser and a Goodman outside. The CI rads were disconnected and all piping removed. How does this system work with the furnace and ductwork and what role does the HW boiler play?0 -
Actually i just read about and it's called hydro-air, right? The hot water is piped into the coil when calling for heat.0 -
Here is a pic of one we are doing right now
about 60% done, See attachment, 2 - 600mbh water coils with 3 TT prestige 399s, pri/sec. Neat job. Tim0 -
too bad...
what is he doing w/ the CI rads? ....kpc0 -
Nice
Nice work there Tim.
I loved the long radius ells.Are you installing the coils on the return side of the equipment?
If thats the case nice job,they work so much better as a pulled thru.
I hope one day soon they will start coming out with split coils so we can stage the the heat like we do the ac.
These are custom coils Don
I could have had them split but using mod/con boilers covers that. Thanks for the remarks. Tim0 -
Going to post them on craig's list. There are 6 or so A & R Peerless plain 3 columns.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
