Solar Electric Panels
JackR
Member Posts: 125
I'm doing a little research for a community that is going to do some renovations on town offices and municipal buildings, they are going to be incorporating solar domestic hot water and electric. I had heard somewhere that solar electric panels only give 100% of their output for about 7yrs or so and then re-rate after that down to as low as 40% over time. Is there any validity to this? If so, What is the expected lifetime?
Thanks in advance,
JD
Thanks in advance,
JD
PV panels should produce plus or minus 5% of rated output for the 25 year guarentee.There was an error rendering this rich post.
They,,,
must be kept clean! Long term accumulation of dirt and grime will reduce their output.0
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
