radiator conversion...
kpc_14
kpc_14 Member Posts: 38
of saving a very large 72" cast iron radiator from the scrap yd.
It was in a steam system and I need to convert it to Hw. Is was in a basement and has two good tapings on one side. Where do i find the special fitting to do this using only tappings on one side so the water won't shour cycle through the rad....ty,kpc
  • Sounds tough Kev,
    Is there any way you can go out of a top bung?
    Dave
  • kpc_14
    yes....
    on the right side I have two openings. up and down. I need a fitting that had threads on both inside and outside. just not sure what to ask for at the supply house...kpc
  • Eric L._2
    Eric L._2 Member Posts: 94
    Tig Weld
    a pipe on the inside of the bushing that runs all the way across the rad.
    Eric L.
  • Eric L._2
    Tig Weld
    Eric L.
  • oventrop
    Oventrop makes a trv that is made for one pipe steam rads. It injects water into the back of the rad to allow the rad to heat up evenly. Check out there web site im sure you can find liteature on it.
  • kpc_14
    I found it...
    in condensate heating. It is a double tapped bushing.
