Is it a problem to have water level 2 inches above \"normal\"
Peter Marren_2
Member Posts: 8
a higher than normal water level can be a problem, like water carry over, steam banging to name a couple. you would have to check the Mfg. listing for your specific boiler. Leaks should be addressed as soon as practical, depending on location and severity. pm2817@aol.com
The boiler at our neighborhood club (AO Smith 5GPM Capacity Steamer) has a water level that is 2-inches above the "normal" line on the boiler/watch glass. It appears that the pump that brings condensate in from a tank cycles on before it should, so the water level is basically always at that level. Should this be repaired ($$) or is it OK?
Next question: when I was watching the boiler tonight, I was surprised how long it ran. I then noticed that the pressure relief valve was releasing a very gentle but steady flow of steam. Is this the reason pressure is not building?
Final question: There is a drip from a big valve (6-inch pipe) on the ceiling, maybe one drip every minute. Should this be addressed immediately?
The burner burns 2.75GPM, so wasting oil wastes big money.
Thanks for any advice.
Steve0 -
water level
the water level might not be a big deal the relief valve isas is the water leak from the pipe0 -
Ed:
How can I reach you? I need steam person, not the oil company to handle this.
Steve0
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
