radiator rating
RJR
RJR Member Posts: 15
forgot the pictures
age thing!
  • RJR
    radiator rating
    I've got a building with a load of these solid radiators. They look like tube type (not thin tube) with the space between the tubes solid (no air gap). Varying heights but if I was to call out the sides as a tube type I would be looking for ratings on a 3 & 4 & 5 & 6 & 8 tube again with a solid section. So if any one has rating I would greatly apprciate it. I did the calulations using tube type and the numbers just seem real light for the building. Thanks in advance for any help
    RJR
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Are they cast iron or kpressed steel?
