Luxpro thermostat
Steve T
Steve T Member Posts: 4
Anyone else having problems with the Luxpro PSPA711 thermostat. We have installed 100+ now having problems with several no heat calls and having to reset the thermostat. Also losing time or date. Called lux not having a problem?
  • Steve T
    Luxpro PSPA711
  • bill nye_3
    bill nye_3 Member Posts: 307
    Battery
    The only ones I've had with problems needed fresh batteries. But, you must have already done that. Nope, no problems.
  • Al Gregory_2
    Al Gregory_2 Member Posts: 2
    I'm a new homeowner who has the Luxpro PSP511a model and have had the problem you describe. The unit was replaced and it still has the same problem occuring about once a week.
  • Phil_17
    Phil_17 Member Posts: 178
    luxpro phased?
    just a stab --is this anything to investigate maybe bad phasig = bab thermo-karma--nbc
    http://forums.invision.net/Attachment.cfm?phasing 24v transf.pdf&CFApp=2&Attachment_ID=30907
  • Phil_17
    luxpro phased?
    just a stab --is this anything to investigate maybe bad phasing = bad thermo-karma--
    or maybe 110v.leakage.
    nbc
  • Lux PSPA711 has a glitch
    LuxPro PSPA711 has a new revision PSPA711A.   I am certain they are aware of the Lux PSPA711 will freeze at random.  Possible Defective Component or Software Glitch.  They should recall these thermostat.  I have seen where the heaters will not turn off due to the thermostat stuck in freeze loop mode.  The temperature got extremely hot inside the house.
  • Steve Ebels_3
    Steve Ebels_3 Member Posts: 1,291
    edited October 2010
    Lot's of problems with Lux
    Do yourself a favor and return it for something different. If the seller will not exchange it ask for a refund. Failing that, just pitch it and get something else. They are junk.
    Que the old HeeHaw song...........
    "If it weren't for bad Lux, I'd have no Lux at all......."
    :)  Sorry.....I couldn't resist...........
  • Bob Bona_4
    Bob Bona_4 Member Posts: 2,080
    I was
    holding back since I saw this post, but with Steve on board, I whole heartily concur. The only good Lux is the one not on YOUR job. Erratic operation, crap display, cheap.
    I don't even use old ones for construction temp stats, they are that bad.
