new boiler have heat but noy so good hot water? can anyone help
Maynard
Member Posts: 74
Do You Have A Coil In Boiler?
You Might Have A Manual Mixing Valve in Between Hot And Cold Pipes Coming Out Of Coil. This Valve Might Be Fully Open.
Picture Would Help.
Picture Would Help.
new boiler heat but not so good hot water
I have a new boiler and steam heat, The heat doesn't seem to have any problems but the hot water doesn,t get hot, or if it does doesn't last I've adjusted the temp. knob all the way to 160 on the boiler but no improvement can anyone help?0
- 167 Indoor-Air Quality
